Making memories
Hi there,
If I get the assert
BPrivate::block* BPrivate::superblock::getBlock(): getNumAvailable() == 0
what does that actually mean? The app is only using 11MB of RAM so it can’t truly be unable to find an available block. Does it indicate a memory leak?
I also hit a GPF trying to delete a pointer that seems to have 0xdeadbeefdeadbeef as the address, so I assume that’s something ugly happening - heap corruption?
So far I tried running with malloc_debug but I don’t see any of the symptoms there. I haven’t gone through the “Advanced Use of malloc_debug” section yet. Is that my best bet?
Thanks!
Experts may give you more details or correct me, but it looks like use after free. The 0xdeadbeef marker is used on malloc_debug to fill freed memory to better catch this case. The assertion I think I’ve seen it when some memory management structures get corrupted due to writing on freed memory or outside the allocated areas, like past an array bound.
Thanks, @madmax - that does match the behavior I’m seeing. I was able to track down -where- the problem is now, the trick is to figure out -why- it’s happening.
Try working backwards from where you delete that pointer. Where was it created and what happened to it during its life ? Maybe you can get some clue of why it is disappearing
Well, it turns out I wasn’t deleting a pointer directly - I was accidentally, in one particular case, returning the wrong pointer. Then that pointer was getting deleted and replaced with itself - which had just been deleted.
So, use-after-free, but in a bit of a roundabout way. Good times!
