Ah, I think I see what’s happening. Things are being renamed (how to prevent this?):
Using X_VND000.SVN;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be.url.svn+ssh (x-vnd.be.url.svn)
Using X_VND000.HTT;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be.url.https (x-vnd.be.url.http)
Using X_VND000.PRI;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be.printer-spool (x-vnd.be.printer)
Using X_VND000.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-work (x-vnd.be-volume)
Using X_VND001.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-volume (x-vnd.be-tskb)
Using X_VND002.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-tskb (x-vnd.be-trak)
Using X_VND003.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-trak (x-vnd.be-symlink)
Using X_VND004.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-symlink (x-vnd.be-scrn)
Using X_VND005.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-scrn (x-vnd.be-root)
Using X_VND006.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-root (x-vnd.be-querytemplate)
Using X_VND007.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-querytemplate (x-vnd.be-query)
Using X_VND008.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-query (x-vnd.be-psrv)
Using X_VND009.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-psrv (x-vnd.be-prnt)
Using X_VND00A.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-prnt (x-vnd.be-pref)
Using X_VND00B.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-pref (x-vnd.be-post)
Using X_VND00C.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-post (x-vnd.be-pepl)
Using X_VND00D.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-pepl (x-vnd.be-mail)
Using X_VND00E.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-mail (x-vnd.be-kmap)
Using X_VND00F.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-kmap (x-vnd.be-input_server)
Using X_VND00G.BE_;1 for /boot/home/config/settings/beos_mime/application/x-vnd.be-input_server (x-vnd.be-elfexecutable)
*Update:
Added the flag -max-iso9660-filenames, which got rid of those errors above, but didn’t prevent the problem. Most icons for applications/folders are missing, just have the standard binary icon for apps, and the grey icon for directories (although some have the correct ones).
Added the flag -max-iso9660-filenames, which got rid of those errors above, but didn’t prevent the problem. Most icons for applications/folders are missing, just have the standard binary icon for apps, and the grey icon for directories (although some have the correct ones).[/quote]
