Ok , I resolved the Haiku issue again - I removed your service from system.
I think quite good if I help you in findings during this phase until your SW still not reliable.
My nightly used as kinda daily driver Haiku as I want to benefit from brand new developments.
Right, I reinstalled the service under my home, and started with direct launch.
First and most important finding :
the 644 permission for the service’s logfile resulted in empty log !!
Just as I changed to 664 , then the log content started to be written there
Now my states - as I documented - first with screenshots :
Finally , HERE will come my next activities in the terminal.
I restarted the service many times - besides it loads my machine heavily - other programs annoyingly slow launching … sometimes Deskbar does not work as expected : does nothing when I want to reach the menu part .. so sometimes I just killed to have access back to programs.
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 09:08 ps index_server
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:17 cat start_index_server.sh
#!/bin/sh
# Starts index_server right after installing it - a fresh pkgman install
# alone does NOT start it, since the launch job triggers on
# "initial_volumes_mounted", an event that already happened at this boot
# before the package existed. Without this, a system-wide install would
# otherwise just sit there until the next reboot.
# Run this once after installing index_server_debug*.hpkg:
# sh start_index_server.sh
# If you're updating from an earlier debug build: also open Index Server
# Settings and click "Reindex Everything" once - the full-text index
# storage location changed, and the new location starts out empty.
set -e
echo "Starting index_server..."
launch_roster start x-vnd.haiku-index_server >/dev/null 2>&1 || true
sleep 2
if ! ps | grep -q '/servers/index_server$'; then
# launch_roster start is a known no-op here more often than not (see
# issue #63) - a *system-wide* install (no -H) not starting is just
# that quirk and this direct launch is a full workaround. A *home*
# (-H) install additionally can't autostart at all: Haiku's
# system-mode launch_daemon, the one "initial_volumes_mounted" jobs
# run under, never scans a user's own package data for job
# definitions - only a system-wide install's. This direct launch
# still starts it right now either way, but a home install will need
# this script run again after every reboot until that's fixed
# properly upstream.
BINARY=""
if [ -x /boot/system/servers/index_server ]; then
BINARY=/boot/system/servers/index_server
elif [ -x "$HOME/config/servers/index_server" ]; then
BINARY="$HOME/config/servers/index_server"
echo "(home install detected - see the note in this script's"
echo " comments about autostart not working for -H installs yet)"
fi
if [ -n "$BINARY" ]; then
echo "launch_roster didn't start it - starting directly instead: $BINARY"
# Redirected so this script (and any terminal/SSH session running
# it) doesn't end up waiting on the backgrounded server's own
# stdout/stderr to close.
"$BINARY" >/dev/null 2>&1 &
sleep 2
else
echo "Couldn't find the index_server binary in either the"
echo "system-wide or home install location - is it actually installed?"
exit 1
fi
fi
echo
echo "Status:"
launch_roster info x-vnd.haiku-index_server 2>&1 || true
ps | grep index_server | grep -v grep
echo
echo "Log file (attach this to any bug report):"
echo " ~/config/var/log/index_server/index_server.log"
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:17 less ~/config/var/log/index_server/index_server.log
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:19 ls -l ~/config/var/log/in
-rw-r--r-- 1 user root 0 aug. 14 09:01 /boot/home/config/var/log/index_server/index_server.log
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:19 chmod 664 /boot/home/config/var/log/index_server/index_server.log
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:19 sh ./start_index_server.s
h
launch_roster didn't start it - starting directly instead: /boot/home/config/servers/index_server
Status:
launch_roster: Could not get target or job info for "x-vnd.haiku-index_server": Name not found
/bin/sh ./start_index_server.sh 9568 1 0 0
/boot/home/config/servers/index_server 9573 10 0 0
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:20 tail -f ~/config/var/log/
FullTextAnalyser: identified Microsoft.VisualC.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Threading.Tasks.Dataflow.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified Microsoft.VisualBasic.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Net.Http.WebRequest.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ServiceModel.Web.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ServiceModel.Routing.dll as "Egyszerű szövegfájl" (translator 22)
FT: document added, retries: 0
FullTextAnalyser: identified Microsoft.CSharp.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ServiceModel.Internals.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ServiceModel.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: slow Translate() (3631 ms, waited 0 ms for sTranslatorLock)
FullTextAnalyser: slow entry (3634 ms, indexed): System.ServiceModel.dll
slow analyser (3634 ms): FullTextAnalyser on System.ServiceModel.dll
FullTextAnalyser: identified System.ServiceModel.Discovery.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ServiceModel.Activation.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Security.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Runtime.Serialization.Formatters.Soap.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Drawing.Design.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IdentityModel.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.EnterpriseServices.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: slow Translate() (1996 ms, waited 0 ms for sTranslatorLock)
FullTextAnalyser: slow entry (2000 ms, indexed): System.EnterpriseServices.dll
slow analyser (2000 ms): FullTextAnalyser on System.EnterpriseServices.dll
FullTextAnalyser: identified System.Dynamic.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Drawing.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IdentityModel.Selectors.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified Microsoft.NuGet.Build.Tasks.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.DirectoryServices.Protocols.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: slow Translate() (2223 ms, waited 0 ms for sTranslatorLock)
FullTextAnalyser: slow entry (2227 ms, indexed): System.DirectoryServices.Protocols.dll
slow analyser (2227 ms): FullTextAnalyser on System.DirectoryServices.Protocols.dll
FullTextAnalyser: identified System.DirectoryServices.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Design.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Net.Http.Formatting.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Net.Http.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Net.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Messaging.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Management.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Json.Microsoft.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Json.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IO.Compression.FileSystem.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IO.Compression.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified CustomMarshalers.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ComponentModel.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Razor.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.ComponentModel.Annotations.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Linq.Expressions.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Mvc.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Collections.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified WindowsBase.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Collections.Concurrent.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Mobile.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IO.UnmanagedMemoryStream.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.RegularExpressions.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Http.WebHost.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified WebMatrix.Data.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified cscompmgd.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Http.SelfHost.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Xml.Serialization.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified Commons.Xml.Relaxng.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.Http.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Xml.Linq.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified Accessibility.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Diagnostics.Tracing.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Linq.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Windows.Forms.DataVisualization.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: slow Translate() (2457 ms, waited 0 ms for sTranslatorLock)
FullTextAnalyser: slow entry (2460 ms, indexed): System.Windows.Forms.DataVisualization.dll
slow analyser (2460 ms): FullTextAnalyser on System.Windows.Forms.DataVisualization.dll
FullTextAnalyser: identified System.Net.Sockets.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.IO.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Windows.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Globalization.dll as "Egyszerű szövegfájl" (translator 22)
Catch up: 200/79236
FullTextAnalyser: identified System.Web.WebPages.Razor.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Dynamic.Runtime.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Web.WebPages.dll as "Egyszerű szövegfájl" (translator 22)
FullTextAnalyser: identified System.Xml.dll as "Egyszerű szövegfájl" (translator 22)
FT: Commit
user ~/Playground/Index_server__service__GSOC_2010_revival/v1.003__debug_mode 10:21
Here you are** YOUR DOWNLOADS
- Debug logs**
https://xtn.sh/rlAg/index_server_and_related_debug_logs.7z
Service log
xtn.sh - Easy and fast file sharing from the command-line.
