Hi! Sorry, thanks for the answers, but probably I didn’t expressed correctly: I try to find which package must install to get an specific library. For example: if I’m trying to compile an application that needs the “libQt5Gui” library, I will need to install the Qt5 package.
IIRC, there is a command that shows, which package from HaikuDepot need to install, based in the library that I’m looking for.
If the issue comes up when you try to build from Terminal, try searching with pkgman should give you some pointers too
“pkgman search libQt5Gui”
Default library is installed with the base package, if you need the headers (etc) too you need to install the _devel package also (hint, if the source uses pkg-config/cmake, it needs the _devel package as they mostly provide the *.pc or cmake files for that specific package
