Llvm_clang doesn't find standard headers by default
Out of the box, Haiku nightly’s llvm_clang package appears to be unaware of the locations of the standard C/C++ headers, such as iostream and bits/c++config.h, causing clang++ builds to fail.
Example:
#include <iostream>
using std::cout;
int main() {
  cout << "Hello World!\n";
  return 0;
Trace:
$ clang++ -o hello hello.cpp
hello.cpp:1:10: fatal error: 'iostream' file not found
#include <iostream>
1 error generated.
As a workaround, I am manually adding the include paths:
$ clang++ -o hello -I /boot/system/develop/tools/lib/gcc/x86_64-unknown-haiku/5.4.0/include/c++ -I /boot/system/develop/tools/lib/gcc/x86_64-unknown-haiku/5.4.0/include/c++/x86_64-unknown-haiku hello.cpp
$ ./hello
Hello World!
Update
In Haiku nightly x86, the llvm_x86_clang package fails to inform its clang++ binary of yet another location, for things like float.h in /boot/system/lib/x86/clang/5.0.0/include. :stuck_out_tongue:
Yes, I recall complaining about this to whoever maintained the clang package some years ago, and apparently they never fixed it…
If anyone stumbles upon this thread, since at least R1Beta2 you want to install gcc_syslibs_devel
