Libpng vulnerability
Does this apply to us?
http://www.us-cert.gov/cas/techalerts/TA04-217A.html
Kev
Yes. libpng is used in the app_server and the translation kit.
But, I mean, is the vulnerability in our version? They said Windows versions of libpng may not be affected. I was just wondering how different our version was from the standard, or if it was different at all.
Sorry, I really don’t know what I’m talking about. :slight_smile:
Kev
the BeOS version is exactly the same as the other UNIX versions I beleive.
Kev
It appears that the solution as suggested by CERT is to upgrade libpng code to version 1.2.6rc1 which resolves the issues… so I would guess it’s just a matter of upgrading/re-porting the code in CVS ?
