The issue that I have is as follows.
In most operating systems, if you click on the right hand side, then it is a right click and if you click on the left hand side it is a left click. However Haiku registers them both a mouse 1.
Also it does not support double tapping (by that, I mean tapping with two thingers at the same time) to left click, it treats it as a single tap.
Is there any way to left click with a touchpad in the cenario I described?
It isn’t a big deal (since I can always use a mouse), but it can get a little anoying.
Please check if there is already a ticket for this problem in Trac.
My bad. Tysm.
