Hello,
I found this in the compatible hardware list:
**Dell Latitude E6400**
Rating: Excellent (everything works… except maybe the camera or fingerprint reader)
Version: Nightly 64-bit (hrev51798)
Started with: EFI (by choice), from USB flash drive
Memory: 4 GB
Processor: 2.26GHz Intel Core 2 Duo P8400
GPU: Nvidia Quadro NVS 160M
Sound card: Intel
Network cards: Intel Wireless WiFi Link 4965AGN (802.11a/g/n)
Additional notes: (None)
Contributor name: Peter
However, for me the sound isn’t working. I have the latest .iso release and the latest updates. Is there something I’m missing?
Also, I can’t figure out how to execute .jar files. Is there an environment variable I need to set? I installed the OpenJDK from the Haiku Depot. I made the .jar executable, but Haiku gives a prompt that it’s a mistake that the .jar is executable. When I try to execute it, it doesn’t work. Thank you for any help.
