I’d like to know if there is a possibility to have a keybinding associated to the keys ⛭+ and ⛭- for screen brightness.
I know there is a command “screenmode -b +/-amount” to do this but I don’t know how to register the binding to those keys.
I meant to those specific keys…
let me show you a keyboard:
Do you see the volume, well that key is not a Function (F1…) key, so as there are multimedia keys there are also keys with brightness function. I’d like to bind the brightness to those keys
to be more clear:
There was some development recentl to support the multimedia keys, but i can’t recall the details. You could check the sources and or the gerrit instance at review.haiku-os.org
Happy to hear that  thank you
 thank you
It’s not done yet, so no, you can’t use these keys for now.
By default, there’s no multimedia key support (far as I know, anyway) but you can map the keys manually in Shortcuts in Preferences. Obviously, it’ll work a bit differently with modifiers than just pressing one key at the top of the keyboard, but I hope this helps!
