a modernized Java compiler written in C++, updated from the original Jikes codebase to support Java 6 language features.
However you should think to change the name.
It’s not my work, I just posted about it.
Why? Does it mean something offensive in your language?
Question for the Java experts. This claims it can compile Java versions 5-8. I checked the Oracle site and indeed, Version 8 is what is offered there. Meanwhile the OpenJDK versioning is up to 25. Very confusing. Does anyone know of a version equivalence table between “official” Java and OpenJDK?
It seems to me that the openJDK matches with the JDK releases…meaning they coincide with other as far as I can tell.
Oracle stopped distributing a standalone “java runtime environment” after version 8. For newer versions, they expect developers of Java applications to bundle a specific version of the JRE together with their application. So each application comes with its own version of Java and there isn’t a system-wide one. But it is still a 10 year old release with only minor security fixes.
For the newer versions, there is only the JDK (which includes the JRE together with the compiler and other supprot tools). So that’s what’s used in most cases for Linux distributions and also for Haiku: you have to install the entire JDK, or we may split it as we usually do (with a _devel package including the compiler and a base package including only the runtime, for example).
Yes, at least Russians will have fun from this name or it will be considered as a slur.
Right, thank you, that is quite clear. So we really are at Java version 25 (well, 24 for Haiku) and this program can only be guaranteed to compile 10 year old code. Doesn’t seem worth the trouble of compiling and packaging, then.
It is vulgar word that means “ass” in Russian.
Strictly speaking, “джопа” or “йопа” doesn’t mean anything in Russian.
But жопа does.
You consider “ass” as vulgar? In Germany we use it almost daily, and for me ass is no problmematic word! See my nickname here! No problem…
Everybody has an ass, and that is good so, good to have!
Russian жопа it is like in german Arsch.
No problem, as long as it is for russian language only! You can call me Jopa and I don’t care! I don’t speak russian!
What I want to say is, there are a lot of words which are translated in other languages (there are more than 7000!) who come out strange, vulgar, or funny… Its like this, and yes, you can call me “Arsch”, no problem with it!
Jopa sounds nice to me!
Let the developer call it what he likes!
Well, it’s clear that when you don’t understand the language, you don’t care. Those who do care. Of course, as I already noted, “Jopa” is not an exact phonetic equivalent of the Russian “ass”. Well, if Russian speakers are annoyed by that similarity, they should contact the author of the project.
For me it’s more amusing than annoying. It’s an invitation for silly jokes.
By the way, the fact that it is developed by Claude makes it more amusing.
You can suggest this star as the compiler logo.
For the newer versions, JRE is available from Eclipse Adoptium project (aka Eclipse Temurin)
Although it is little known, Oracle used to distribute JRE 9 and 10, and it’s still possible to download them using the direct links: https://gist.github.com/starchivore/f1ef4100b3117919496cedee67d11f8d
But! No one should really use Oracle Java these days, unless they are willing to pay for it or deal with legal consequences.
https://www.reddit.com/r/sysadmin/comments/165kzxg/oraclejava_is_knocking_at_my_companys_door_and/
