ah ok I see… so there is no need to have it for me atm.
Go ahead and do better programming for the developer using your editor…
I had now written a new theme engine and ported a few themes from Notepad++:
Before you get too hyped: It still needed colors for each language. It had only ported the python parts of the themes. If you use any other language with that theme, syntax highlighting will not work.
Wow great work… Very surprised about the speed you did the theme.
Python has only a few colors, so this could be done fast.
The new Version with all the new features is now out!
Version 9.1 is now out. It fixes a bug when using the split view the settings are ignored.
I’m working on a PyQt6 Port now. I hope that Haiku will support Qt6 soon.
There is a recipe for Qt6, but it’s not enabled atm: qt6: bump version · haikuports/haikuports@e269595 · GitHub
