Cc generated/objects/haiku/x86/release/add-ons/media/plugins/avcodec/libavcodec/adpcm.o
/boot/haiku/src/add-ons/media/plugins/avcodec/libavcodec/adpcm.c:760: warning: ADPCM_ENCODER' redefined /boot/haiku/src/add-ons/media/plugins/avcodec/libavcodec/adpcm.c:731: warning: this is the location of the previous definition /boot/haiku/src/add-ons/media/plugins/avcodec/libavcodec/adpcm.c:728: unterminated#if’ conditional
…failed Cc generated/objects/haiku/x86/release/add-ons/media/plugins/avcodec/libavcodec/adpcm.o …
…skipped libavcodec.a for lack of <src!add-ons!media!plugins!avcodec!libavcodec>adpcm.o…
…skipped avcodec for lack of libavcodec.a…
…skipped haiku.image-copy-files-dummy-beos/system/add-ons/media/plugins for lack of avcodec…
…skipped haiku.image for lack of haiku.image-copy-files…
…failed updating 1 target(s)…
…skipped 4 target(s)…
…updated 1435 target(s)…
$ …updated 1435 target(s)…
I just updated to r23117 and ran jam -q haiku.image. the resulting image file is empty except for a home folder ( probably added when I mounted the image in BeOS ). I believe this was caused when links was added to the jamfile /haiku/trunk/build/jam/HaikuImage ( r23089 ) as the resulting image file has been empty since then.
There is no error. Jam completes as expected and reports that it is copying the files to the image, but there are no files in the resulting haiku.image file.
After remarking out the section for links in /haiku/trunk/build/jam/HaikuImage the jam completed with all the files copied to the haiku.image file. ??? This doesn’t make any sense as jam must be run with a command line argument to activate the links download. Any ideas what is going on?
You should ask on the Haiku Development list or file an issue on Trac (http://dev.haiku-os.org) - Ingo would probably be able to help you track this down much better, but he doesn’t read these forums AFAIK.
