Iterate over a BObjectList?
I’m having some trouble getting started with C++.
For example, how can one iterate (with EachElement) over a BObjectList? Forgive me if I missed the appropriate documentation with an appropriate example. My sample code looks like this:
#include <iostream>
#include <ObjectList.h>
#include <String.h>
class ListDemo
public:
	ListDemo(void);
	void DoDemo(void);
	void PrintIt(BString* str);
#include "ListDemo.h"
ListDemo::ListDemo(void)
void
ListDemo::PrintIt(BString* str)
	std::cout << str->String() << std::endl;
void
ListDemo::DoDemo(void)
   // Create a BList to store strings
    BObjectList<BString> aList;
    // Add some strings to the list
    aList.AddItem(new BString("alpha"));
    aList.AddItem(new BString("beta"));
    aList.AddItem(new BString("gamma"));
    //aList.EachElement(PrintIt); //HOW???
Thank you for your attention!
Your PrintIt function has to be either a “free” C function, or a static method. You are trying to pass a class method, which takes an extra hidden argument (the “this” pointer) and so has an incompatible type
Hi @retronym67,
The signature of PrintIt is wrong! It must match the type parameter provided to BObjectList and needs an addiitonal void* param.
The correct definition would be:
BString* PrintIt(BString* str, void* param)
	return str;
And EachElement should be invoked as:
aList.EachElement(PrintIt, nullptr);
Replace nullptr with whatever value you need and adjust PrintIt accordingly.
Also PrintIt must return 0 if you want to continue the iteration, str to bail out.
If you are using C++11 or higher you can also use a lambda that does not capture:
auto lambda = [](BString* str, void* param)
	return str;
aList.EachElement(lambda, nullptr);
Or more concisely:
aList.EachElement([](BString* str, void* param)
						return str;
					}, nullptr);
Lambdas decay to free functions or static methods as long as they do not capture anything.
Thank you! That’s how it works for me:
#include <iostream>
#include <String.h>
BString* PrintIt(BString* str, void* someContextParam)
	return 0; //continue with the iteration
int main() {
	BObjectList<BString> list;
	list.AddItem(new BString("alpha"));
	list.AddItem(new BString("beta"));
	list.AddItem(new BString("gamma"));
	list.EachElement(PrintIt, NULL);
	return 0;
