Hello! I am new to Haiku and after installed Haiku I have issues with the Touchpad. The Touchpad ist Not working. I have an Lenovo IdeaPad L340-17API with an AMD Athlon 300U and 8 GB RAM. I also have issues with the Audio and WiFi.
Ahoy @egor_bordunov ,
Your report is a bit generic to answer to these issues.
Is your Haiku instsll
→ 32 bit
or
–>64 bit
→ Beta5 version
or
→ one of a Nightly version ?
if so : which one ?
(you can find it by invoking About Haiku, which can be found in
Deskbar at the top. In my example below it is translated to my native language - it is possible for your languge if you installed Haiku that way, but the Haiku’s standard objects can be found on the same position.)
→ About Touchpad : you had not clarified what is your issue,
however without question as as such Ideapad laptops counts as modern hardware – I have a hint for you :
Touchpads in some modern hardware connected via i2c bus by manufacturers. You may have such hardware.
One contributor started to work on this area to improve i2c related drivers especially HID devices.
You can read about it at following forum post
If you want to test how it progresses, you may change to 64 bit Haiku Nightly version, as it won’t appear in Beta5 soon.
The contributor added the first fixes in hrev58523 - that was committed recently and that Haiku version was compiled and made available for public – you could see in my example : as I am already on hrev58523.
→ About Wifi : you had not clarified what is your issue.
→ About sound : you had not clarified what is your issue.
Kind regards,
Everything does not work with the touchpad. It is not recognised and I can’t move the mouse with it and it doesn’t work when I click on it either. The WLan is also not recognised, i.e. the WiFi card in the laptop and audio
Ich habe the Nigthly Build (hrev58523) because it hast the GPU Driver and 64bit
Welcome with Haiku !
Can you type listdev in a terminal, to say us what model are your audio card and your wifi card ?
