A DefaultQueryTemplate I created doesn’t seem to be picked up. To refresh your memory, see the section of the User Guide’s Attributes Workshop.
I created a folder at ~/config/settings/Tracker/DefaultQueryTemplates/
called application_x-feed-entry
for @jaidedcd’s Pogger. I adjusted the folder’s columns to show Status, Description, Feed, When.
Only, when querying for “Feed entry” && “New”, I don’t get the results in the intended column layout, but one showing Name, Location, Size, Modified. Weird, because I don’t have a DefaultQueryTemplate showing “Location” at all…
FileTypes prefs correctly shows the application/x-feed-entry type.
As a test, I created another DefaultQueryTemplate for audio/mpeg. That one works and a query for MP3s shows the defined attribute columns.
Any ideas anyone?
