Dear Haiku community, I would like to use our OS in my desktop.
I’ve tryed to format with BeFS my hard disk, but when I finish the process (using a live USB), the partition is unrecognized by the bootman, even the Drive Setup.
I have a SATA disk, in a Intel motherboard, with a Realtek ethernet card (Haiku-compatible). My soundcard is a HDAudio, works pretty good.
I’ve used GNU Linux and FreeBSD in the same PC, but in FreeBSD I have no sound (but in Haiku, that soundcard works well)
Well, you must have formatted the HDD with DriveSetup, maybe launched from inside Installer. Did you choose a filesystem during that process? If so, was it the Be File System?
That is very strange, note the process to format a drive in Haiku goes like this.
If you want’ to use the whole drive, initialize the MBR, otherwise make sure you have an avaiable partition, make it a primary partition to be on the safe side (I think haiku supports extended partitions but haven’t tried and it’'s obviously less tested).
Create a BeFS partition.
Format the BeFS partition… note you have to format it after creating it unlike some other systems were it is automatically formatted after creation.
Then from the Installer select it from the dropdown to 'install to. If it doesn’t show up in the drop down then you didn’t complete one of the above steps, or there is a bug.
No problem, but don’t expect this bug to get fixed if we can’t reproduce your issue as we are kind of flying blind on this end… Untill we can get concrete info on what’s going on.
