Good day,
Would it be possible to host a repo for Haiku on Gitlab? I plan to do some testing and would like to set a Gitlab project as repo to host the packages.
Any hints on the topic would be much appreciated. Thanks.
Regards,
RR
Good day,
Regards,
RR
You can mirror github repository:
But to host packages, I suggest using a dedicated server, not gitlab!
Good day,
@marcoapc, yes, you are right. Best way is to host own repo… besides, there is already a script to set up the repo for hosting haiku packages. Nonetheless… I was thinking that I could do the same as with Arch, where I just create a couple of files and ´voila´ there is the repo (namely the packages database files), directly from pacman, then just need to add it to pacman.conf.
I guess there is nothing similar on Haiku.
Thanks @marcoapc
Regards,
RR
