Is it possible to import/edit keymap?
Hello everyone,
I have a tiny question about my Haiku keymap. I use a US-international keyboard, which works fine, but there are a few characters I’m missing from when I was on Linux. For instance, in French, we have œ, which was linked to AltGr+k, and I also use extensively the middle dot · (which was AltGr+x). I would love to have them back. Is there a way to create, edit and/or import keymaps to use in Haiku ? I did not find the option in the Keyboard Disposition menu but I may be missing something…
Thanks in advance for your replies!
Hi,
Yes you can edit the keymap. Hold the modifier key you want and then drag&drop the character onto the keymap in the right place.
There is also the alternative of hand editing the files, but that is a bit more fidly
EDIT: seems to only work if you start holding the modifier with the keymap app focused, this is a bit annoying. we should fix that…
Thanks for your reply !
I was trying to copy-paste stuff but to no avail… Drag&dropping works indeed !
EDIT: Strangely enough, it worked flawlessly for œ and ·, but not for Œ (so AltGr+Shift+k). Skill issue on my end ?
EDIT2: Okay, strange bug: For AltGr+Shift characters I have to drag&drop the wanted character BEFORE tapping the dead keys in order to change the key. If I do it the other way around, it just doesn’t work for whatever reason. No problem when I only have one dead key. Where can I file the issue ? https://review.haiku-os.org/ doesn’t seem like the place @nephele
The bug tracker is at https://dev.haiku-os.org
One can alternatively edit the keymaps with a text editor:
First “dump” the currently active keymap into text format:
keymap -d > my_keymap
Then edit with your preferred editor, and finally load it back:
keymap -s my_keymap
Then from the Keymap preference app you could “Save as…”.
Just a heads up: AltGr sadly is not a separate key from “right Option” on Haiku ATM, sadly.
