Yes, I was speaking a bit broadly ( for the BSDs ). Both Open and Free are lowering the focus on it ( officially, for FreeBSD ).
As far as Debian/Devaun goes, 32bit kernels/installers are out. Any distro dependent on Debian, will have to follow, or do a lot of legwork. However, this doesn’t change LTS, for 32bit releases.
I truly hope Alpine continues to support 32bit, until the Linux kernel has phased it out too far (note that the kernel will retain some arm 32bit support). I use Alpine, on some of my old systems. Even on 64bit systems I use a 32bit installation, with a 64bit kernel.
As for Slackware, Gentoo, and everyone else, they depend on the Linux kernel. Unless someone makes a fork, they won’t have much choice.
Keep in mind, the kernel isn’t dropping 32bit support “immediately”. But they are officially “phasing out” x86 32bit support.
With that aside, you can expect to see less and less support for full video support. Initially, not so much with the actual drivers. But as an example, WINE has for sometime needed you to modify the registry; if you want to get correct 2D/3D accel. You have to tell WINE not to use 3D acceleration for doing the 2D acceleration. It is fine on newer GPUs and drivers; but some older drivers can’t render correctly, that way.
Void Linux is a good example of this kind of progress. I’m seeing more and more video devices getting reduced functionality, with Void. This isn’t directly related to 32bit hardware, as it also affects older 64bit hardware. This has to do with Wayland/Xorg and Mesa moving forward, and Void’s Mesa configuration (less inclusion of older Mesa models [Amber and Crocus?]).
Now, if someone still produces fairly complete 32bit binaries, you can likely use the last 32bit kernel ( what/when ever that may be) with them.
Also, you’ll probably see the Pentium I drop, before Pentium 2/3/4 and dual core 32bit CPUs. It is a phase out.
