I’m trying run Haiku on an Acer TravelMate 803LCi computer. This includes an ipw2100 wireless adapter, which is detected by the system and the appropriate /dev/net/ipw2100/0 device is visible.
The syslog contains the following lines:
KERN: IPW2100: installing interrupt handler on interrupt line 10
KERN: IPW2100: loading firmware /system/data/firmware/ipw2100/ipw2100-1.3.fw
KERN: IPW2100: microcode did not validate itself
KERN: IPW2100: loading microcode failed
KERN: IPW2100: failed to load imcrocode and firmware
When I’m trying to set the WEP passcode with setwep I get the following error (several times):
set80211: error in handling SIOCS80211
I’m new to Haiku and at this point I have no idea how to proceed. I would be happy to provide more information or help debugging the problem if you can guide me on what to check.
just a quick (perhaps dumb ) question. You did not forget to unzip the ipw2100 firmware did you?
I have the very same card in an IBM X31, and mine works, obviously after extracting the corresponding firmware in /boot/system/data/firmware and in the ipw2100 folder. reboot, set settings to DHCP (in Preferences/Network) and go.
