IPv6 Improvements
Maybe worth pointing out that with the recent IPv6 improvements, I now get a 10/10 score from test-ipv6.com (mainly due to the NDP multicast fixes and the IPv6 Path MTU support):
That’s with a statically configured IPv6 address, but seems to be pretty stable with that now.
Thanks for all the work on IPv6 support!
Speaking of NDP, a while back I noticed that the module called ipv6_datagram seems to only do NDP. Should we rename it?
I think it still needs some thought how it all should work together (with the icmp6 module - and then there is also the ipv6_datalink stuff in there)
IPv6 is very important to ensure Haiku is not stuck in the past. So my biggest thanks to everyone working on it, code, testing, or general feedback. Thank you! :slight_smile:
