Note: this is a cross-post with the haiku-development mailing list.
As announced in a previous email, I am working on a tool that integrates haiku-format, the tool maintained by @owenca, with Gerrit, in order to automate a lot of the manual style checking that is going on by contributors reviewing patches. I am now going to share the first pre-release, version 0.1. The main accomplishment in this release is that the logic for fetching a Gerrit change, running the diffs through haiku-format and then posting the outcome to Gerrit is implemented.
The current state of play can be found in the haiku-format-bot Github repository.
This is the first step towards having a fully automated style checker, but there is much to do. For the bot itself, I designed the following roadmap:
- Version 0.2 (exp. February): Add a command to the repository to repeatedly self-select applicable changes and run the formatting check over them.
- Version 1.0 (exp. April): Run haiku-format-bot as daemon on the Haiku Infrastructure and provide value to the project.
Besides the development on the bot itself, there is also going to be work on haiku-format to get it up to speed. In particular, I identified the class member formatting improvement as a must-have, as well as reviewing what we can do with the builder syntax used in layout builders (though that’s more of a nice to have in my current opinion).
I also suspect that some of the test runs will show reformats that need more discussion. For example, in the most recent run adds spaces after C-style casts. I suspect we will be finding more examples that need discussion.
Beyond the work on the code itself, I will do the following over the coming few weeks:
I will create a service account on Gerrit to run the bot, so that it no longer runs under my name and is more recognizable.
Create a label on Gerrit, that shows the evaluation of the style adherence if the bot is run. My suggestion is that for now it votes a 0 if there are changes, and +1 if no reformatting suggestions are made. I think introducing negative votes is a separate discussion, and we should have that after we have more experience with the bot and its output.
Organize discussions/votes on potential changes to the Coding Guidelines and/or the configuration of
haiku-formatbased on new cases we are finding during the trial runs. -
Continue trial runs over the coming weeks. Initially this will be individually selected changesets, but if all goes well, the bot will start running over more recently updated changes semi-automatically.
I will keep updating everyone on the progress, but feel invited to review the code and to post any ideas/worries/notes during this process.
