Installing Paladin
sorry, i want to ask…
how to install n run paladin on haiku (vm)?
Did you install the Paladin package already?
emmm… i think no
Well you should be able to install paladin from pkgman (or HaikuDepot).
can’t found it
Paladin is in HaikuPorts repository, witch must be enabled.
You could pull down the older version of Paladin from BeShare which includes PalEdit (similar to Pe). Just be aware that it’ll complain about a missing library which can be installed via pkgman.
You have to set the new haikuports repo, e.g. from Terminal with
pkgman add-repo http://eu.hpkg.haiku-os.org/haikuports/master/repository/$(getarch)/current
