Many of us use large usb drives (16GB and above capacity usb sticks/SD cards) for creating Haiku boot disk, this guide is for installing Haiku to the remaining free space on these drives. This method is useful for testing new hardware or introducing Haiku to friends.
Note:
Have tested with Haiku R1/beta5 64bit, on Laptops and Desktops systems that only have UEFI.
I used Linux Mint “USB Image Writer” to create Haiku boot disk.
Once booted from LiveBoot.
1, Open DriveSetup, Select empty space on your liveboot usb drive and create Partition.
3, Open HaikuInstaller and install onto newly formatted Be File System(“Haiku-USB”) on your LiveBoot drive and install.
4, Once Installation is completed, reboot with LiveBoot drive plugged-in and hit “space bar” for boot loader options.
5, Select “Haiku-USB” from bootloader menu “Select volume/state” and hit “continue booting”.
You may delete the original liveboot partition(1.5GB) if your are not planning to install Haiku on other systems. If not deleted, you’ll have to hit “space bar” for boot loader options every time the system is rebooted.
You can also send us your tutorials, besly is always happy to receive new contributions. And they are centrally accessible and can be found via a menu.
Well, it works surely, but 1 thing missing as warning, and 1 thing can be enhanced.
1 thing missing – to warn :
If your system is UEFI and you boot in UEFI mode from the USB drive, then you can use the original Installer partition to anything, but do not delete/modify the “haiku esp” partition. As then you cannot get into Boot menu, as the Haiku UEFI bootloader is there !
To avoid the entering boot menu with hitting [Space] at boot time - you can install Bootman - the Haiku boot manager.
Just BootMan missing - if you install that also, then the bootable partitions appears - if you configured that well – that also enables to launch 64bit Haiku on Legacy only BIOS systems.
This Bootman Installer and config wizard is in Installer’s menu (the pictures file names contains the necessary infos about the steps ! Hovering mouse on the picture shows the text at the bottom of the picture - to be able to read all text bring the mouse pointer exactly to the text - at the bottom on the picture . )
