Hello everybody, i have created a package which should store the source code in / boot / system / develop / sources.
After the installation I don’t see the folder in the directory.
The same problem with documentation.
Is this a bug or are the Haiku directory itself reserved.
Regards Lorglas
Haiku cant handle source packages AFAIK.
No, that’s pkgman which can’t; if you drag and drop the package it should and does install like any other. If you don’t see anything show up, you might need to reboot, though.
After i reboot a lot of time, this packages are avaiable.
so, problem is closed. thank you.
