Hi all im a new to haiku OS. I install haiku on my old pc, after install wont boot from hard disk. Can help me to install on hard disk, and boot from hard disk, because after install cant boot from hard disk. Always from usb stick. And i try to preference in tool installer for boot from hard disk but incompatible says.
have you set active partition?
How to set active partition ?
when you formatting
No active partition sir
did your hdd have been initialized? after initialized into intel partition⌠i create a partition and see this
âActive partitionâ is needed if you use an âintel partition mapâ (suitable for booting in BIOS mode). If you use GPT partition map, it isnât needed, thatâs more suitable for booting in UEFI mode, but in that case you need to manually install the bootloader (we need to automate this in the Installer, it has not been done yet).
In the case of UEFI: https://www.haiku-os.org/guides/uefi_booting/
got it⌠thanks for clarification
Welcome to Haiku.
Once you have booted, you will want to install applications from Haikudepot. If you are having problems, take a look at this thread:
Thanks all the problem is clear, haiku boot from my hdd laptop.
hooray⌠+1 again haiku user âŚ
