That looks great @3dEyes! Are there any remaining issues that may prevent Haiku support from being upstreamed in the meantime?
Native audio and video output plugins for VLC 3.0.11:
You continue to amaze me! Fantastic and important work youâve once again are delivering to this community.
Thank You
I wanted to ask you since ages: could you tell me, what that flame icon is in your deskbar? Also the icons above the deskcalc replicant?
Great work @3dEyes. Where can this be downloaded, perchance?
Thanks a lot @3dEyes ! Been waiting/hoping for a modern VLC on Haiku for a long time
Is this already available in haikuports or pkgman?
This. Is. Awesome. ![]()
Flame icon: Haiku Depot Server
Icons above the deskcalc itâs my smarthome contoller (on/off): chromakey screen drive, table lamp, 3d printer and floor fan
Oh dear, you are a nerdy hacker, arenât you?
Good work on VLC! ![]()
You havenât seen my robot army yet!
They will come for you!
Gaaww⌠Haiku flag waving Minionbots! Now Haikuâs world domination is inevitable!
Thanks for your great work !
Just a question: if I have understood well, the only VLC âfunctionâ that work under Haiku is the playing, right ? (no en/transcoding, etc)
If so, why donât you evaluate to port&maintain MPV player instead (which is more minimal, in Haiku feel) ?
Yes for now.
I only do what Iâm interested in at the moment. VLC is currently my interest. A hobby should be fun, not a duty.
Great job, works wonderfully!
Unfortunately, it is impossible to compile for 32-bit. The gcc compiler crashes when building.
Update: Fixed
Can I try it on 64bit Haiku?
Yes, it is already in the depot.
Great, thanks!
@3dEyes, seems it has been build for 32bit?
https://build.haiku-os.org/buildmaster/master/x86_gcc2/?buildrunDir=&viewMode=expanded
