Nightly users will need to “re-add” their release repos to update to hrev55184 and beyond. This change is part of a long-term improvement of our haiku / haikuports repo identifiers.
These commands need run in the terminal.
Check your current repositories:
pkgman list-repo
Nightly Users
Re-add HaikuPorts
pkgman drop-repo HaikuPorts
pkgman add-repo https://eu.hpkg.haiku-os.org/haikuports/master/$(getarch)/current
Re-add Haiku:
pkgman add-repo https://eu.hpkg.haiku-os.org/haiku/master/$(getarch)/current
R1/beta2 users
Re-add HaikuPorts
Summary
The “identifier” will change from https://hpkg.... to tag:haiku.... for both Haiku, and HaikuPorts on nightly installs (this identifier will only change for HaikuPorts on r1beta2 installs) Once you see the new identifiers, you have been successfully changed over to the new repo id.
This change will not be required for r1/beta3 users once it comes out
