AFAIK haiku load packages file from /system/packages …
can we load package from its subfolder…
let say i have folders /system/packages/office and office apps package and dependencies place there.
and other folder /system/packages/game and game package and dependencies place there…
planning is… can switch mode lets say i want to do office work and with lets say boot switch it load only from office subdirectory…
becase when i install a LOT of package… it will be longer to boot… i dont know it will usefull or not.
it will similiar with porteus linux cheat code .
Why a folder deeper as packages? The administrative folder in packages with the recover packages, if you want to start a older version of haiku, after problems past an update, make the system slow.
No, this is a system directory, stataes can’t be subpartitioned into arbitrary categories.
We already allow installing packages into different dirs at the same time ( /system vs /boot/home/config), so you can add packages at will if you want without having them in the default state, the only thing missing would be a good UI to manage that, but that just aswell be a third party package.
This assertion is wrong afaik , Technically resolving deps could take slightly longer, but “installation” is basically instant. If your boot takes too long it’s probably not this (and if it is it might be a bug)
