I was curious of how hard would it be to update the Application and Preferences folders in the /boot/system/data/deskbar/menu to have the traditional icon folders?
I think that the reason why theyâre looking different outside is that theyâre looking different inside. This way people are seeing that theyâre not really folders but something different. Searching this forum for âsystem foldersâ, âgrey foldersâ or âblue foldersâ, you will find few discussions about the subject.
When users are customizing Deskbar menu, real folders are used, so why not use real folders from start? I personally donât understand but there must be a good reasonâŚ
The blue folders are used to merge the content of several other folders together.
This allows DeskBar to show items from 4 different locations:
- /system
- /system/non-packaged
- /home/config
- /home/config/non-packaged
So you can have a mix of âautomaticâ entries (included in packages, they will appear when you install the package and disappear when you uninstall the package), and âmanualâ entries (that you create yourself, or for example if you install old BeOS apps using the legacy softwarevalet package installer).
They are a kind of extended symlinks that can point to multiple places. But these places are just plain standard directories.
That being said, this has nothing to do with the folder icons. We could certainly add the icons to the underlying folders, not sure why thatâs missing, it looks like an oversight. Then Iâm not sure if the icon will be âtransferredâ to the âblue folderâ, but we can make that happen, too. Itâs just a matter of someone writing the code to make it work.
