Iceweasel is pretty sweet!
I thought someone might like to know that Iceweasel working really nice now.
I was able to load the Our World In Data homepage in decent time, and the text, images and plots all loaded on the page.
David
Thanks, but we all knows it for some months…
The Block around the moving cursor is a bit irritating, otherwise it’s great, just updated to 139
It has been dropping me into the kernel debugger once in a while. How do I get out? The keyboard (either one) works to input printing characters, but no “Enter”. Other threads go on functioning, so I feel like it might be OK to at least call for an orderly shutdown.
Iceweasel displays Youtube videos just fine, but only displays a blank when I try to view the radar video in Accuweather. The same is observed, (or rather, not observed) with the other Firefox clones, e.g. Librefox, Floorp, etc.
The same hardware has no problem with Linux. CPU is the Intel i3 with its embedded video.
In case others struggle with the kernel debugger issue reported above - I find that I can exit with <ctrl>\.
Then I can select “Restart system” from the deskbar, OK all the crash popups from Iceweasel, and then select “Restart system” again. Feels better than just holding the power button down.
