HVIF with PNG etc
Is it possible to export icons from png to HVIF. Unfortunately, neither the Icon-0-matic can not import anything (gif, bmp etc…)- he can’t even open and load them to the program - and Wonderbrush can not export other formats to HVIF.
To import to HVIF, I think it has to be from another Vector graphics format and not from a Raster format.
With that being said you could convert PNG to SVG and then SVG to HVIF.
You can do the first part here: http://vectormagic.com.
SVG also tried to import the icon-0-matic, with no result:/
In general, could use an imaging rate of use I-0-M, the apps is horrible to use. This should be forbidden;)
