Since I could not find anything using google: howto upgrade Haiku from CD/DVD?
How can I add a CD/DVD fetched from https://www.haiku-os.org to repositories scanned by pacman and then upgrade as usual?
Any hints?
Any hints?
Open “Terminal”: pkgman full-sync or just pkgman full
Or start SoftwareUpdater
Is it that what you mean?
Or install?
I think he means adding a CD or DVD as an install source to update with pkgman or Software Updater. Like you can add a CD as install source for apt under Debian Linux.
No idea if that´s actually possibly. Never seen or heard of anyone doing that. Maybe a mirror of the Haiku and Haikuports repo on a local webserver. But that would mean way more data to download than just a regular upgrade.
Hi,
I think, i you install from the cd/dvd over the installed version of Haiku the system will be updated, but i don’t know if you personal data will be kept.
Regards lorglas
Can’t you just pkgman install /cd-or-dvd/system/packages/*
IF the CD was properly set up as a repository (which AFAIK Haiku installation CDs are not) then it would be possible to do pkgman add-repo /REPOCD
, I suppose.
Would only work if network where available. Upgrading from CD/DVD would be nice. Might be possible, since the packages are on DVD/CD. But does the CD/DVD image have all necessities to be a working repository?
And if not – any way to build a repository out of any downloaded CD/DVD? And how would this have to be done?
