How to run a php script from Terminal
Hey there,
I’m new to this operating system which we will use sooner or later for our radio automation system.
I have a php script that takes the current song info and sends it to our streaming provider.
How can I run t this script under Haiku? I’ve come across is: http://araneum.koppin22.com/doc-haiku-inst.html
I guess that’s a requirement in order to run a php script right? But how can I run is script from a terminal window though?
Thanks in advance guys
Texcor
to run a php script fro the Terminal:
  1. Install php http://dl.koppin22.com/php-5.3.5-haiku.zip
  2. type:
php scriptname
Where scriptname is the name you gave your php script.
