I need to add <LaunchRoster.h> in a Qt project i am porting, adding it directly in the source doesn’t work, so how can i declare the path of the private headers in the pro/pri files? i couldn’t find this info on the net.
Responding to myself
Add the following line to the target pro file
INCLUDEPATH += /full_path/to/to/the_header_file_dir
In my case it was
INCLUDEPATH += \ /boot/system/develop/headers/private/app
If you need more headers from the private section that are in different subdirs you need to give the full paths of all of them seperated by a space
like this
INCLUDEPATH += \ /boot/system/develop/headers/private/app \ /boot/system/develop/headers/private/interface
Now i need to find out how to do that with Cmake, if anyone knows please let me know.
-DCMAKE_CXX_FLAGS="-I/path/to/the/headers"
Yes, that’s one way to do it, there is another way, that is by adding the following line to the Cmakelists.txt file
include_directories(/boot/system/develop/headers/private/subdir)
And you can add the library you need to link against this way
target_link_libraries(${TARGET_NAME} libname here)
example:
target_link_libraries(${QTERMWIDGET_LIBRARY_NAME} be)
Do you know a similar way to yours but then for linking?
Something like
DCMAKE_LDFLAGS="lbe"
