HydraDragonAntivirus/HydraDragonAVHaiku: HydraDragonAntivirus For HaikuOS
I have this project I want to change this file icon HydraDragonAVHaiku/HydraDragonAntivirus/Resources.rdef at main · HydraDragonAntivirus/HydraDragonAVHaiku
with this data HydraDragonAVHaiku/HydraDragonAntivirus/assets at main · HydraDragonAntivirus/HydraDragonAVHaiku
Looking at the Makefile the rdef is already used to put an icon to the binary?
Wow so fast answer! Yeah, I am using at Makefile and didn’t touch default things yet.
Didn’t check the build though
I using genio for build with clang.
Quick check with “make” there is a trailing whitespace after Mainwindow.cpp. And can’t see the icon added to the binary
I using vector_icon
You may want to create an alternative Be/Haiku-styled version of the icon (3D-like, in perspective) for who wants to use it.
