hi…I have a computer DSL setup…I comfigured PPPOE by sudo pppoeconf then enter my username and password in ubuntu toconnect to internet how can I connect to internet using Haiku…?
There is no PPPoE support as yet. When there is, it’ll invariably have a graphical configuration panel
The last time this came up I was surprised at how relatively common it still was to get a DSL unit that requires PPPoE as routers have been standard-issue in this part of the world since day one… for now, you’ll need to get a router to get Haiku online in that configuration.
I would also like to know how to do this directly in Haiku.
Another solution which I use is to configure the modem or (wireless) router to connect using PPPoE (giving it the user/password). You can usually login in to your modem or router settings user interface with your web browser (WebPositive in Haiku).
Regards,
hey68you
