Since the full implementation of font rendering is missing from the binary distribution, and since it’s an important feature, could somebody post a how-to guide on how to compile (part of) Haiku to enable the sub-pixel font rendering ?
(If it’s legal to do so, I’m not sure about it).
To get sub-pixel rendering to work, you have to compile Haiku with the “–include-patented-code” flag (minus the quotes). Just remember to jam -aq @alpha-cd. That “-a” flag added to jam will make sure that all the elements of haiku know about your change to the code.
Could you put here the full commands to be entered in the terminal ? I do programming in c,c++,java,php but i don’t know yet how to compile with gcc or recompile an os entirely.
If using Linux: Get buildtools source, build & install Haiku’s jam, compile the buildtools (configure does this).
run configure with switches you want (./configure --help); found in root Haiku folder. Creates generated subfolder unless you specify different name. Contains object and binary files created during compile. Run configure only once or again if you remove generated folder (or buildtools).
jam with switches; jam --help
You can also jam a single component if you know it by name. Or change into a source folder and jam everything in one directory.
Read the link above to give you greater information & get you started.
sorry for digging out such an old thread, but it seems that something has changed in the buildprocess because the above mentioned configure switch has no effect on the freetype library (ftoption.h still has subpixel rendering commented out).
Freetype has been moved out of the Haiku repository and is built separately. When building Haiku now, the pre-build Freetype package (and headers) are downloaded and extracted.
As such, there’s no longer an easy way to fiddle with the freetype settings when you build haiku without first building your own freetype package and replacing the downloaded copy with it.
if one would subpixel rendering and subpixel hinting in Haiku, follow the steps below. It’s just a quick and dirty approach without package management but works as expected:
Configure the build cd freetype-2.5.2
nano include/config/ftoption.h
Remove the comments from the necessary parts
Build it ./configure --prefix=$(finddir B_COMMON_DIRECTORY)
make -j 4
make install
After a reboot you can verify if you are using the new libraries with
listimage | grep freetype
I have to admit that to me Grayscale rendering looks better in Haiku than Subpixel Rendering, now that i have tested it (as opposed to linux where grayscale rendering looks kinda shitty). It seems that either Haiku is optimized for it or i am too used to it.
