BTW, is there a way to change the image of a particular USB device? In other words, say I wanted my USB thumb drive to show up as a 5.25" floppy diskette (silly, I know, but still…) instead of the usual USB thumb drive image. How would Haiku know to apply that image to just that particular USB thumb drive when it was mounted?
Select the disk from either Desktop or Tracker’s root (“/”) folder… open Add-ons->FileType… and then drop the desired icon in the aptly named “Icon” part of that window.
If you don’t like it… you can “right-click” on the icon, and hit “Remove icon” to restore the original one.
But does that affect all USB thumb drives or just THAT particular one?
Works on a per-volume (parttion) only. And only for those using BFS, I would assume (the only one I’ve tested).
Unfortunately, I cannot seem to change the image. I right-click on the USB icon and go to Add-ons/Filetype and I see a folder icon. I tried dragging a known icon file from the build directory to that folder icon and it does nothing. If I try to Edit the folder icon, all I get is a blank Icon-o-Matic screen. How am I supposed to change the USB icon to something else? Nothing I’m doing seems to work.
I just dropped a text file over it, and got the text-file icon in there, for example. Seems it only allows to “clone” the icon from an existing file type now? Might be a bit buggy, as in the old BeOS days, you could simply drag and drop there any icon you wanted.
I don’t want a file type icon (like a text file, .mp3, video, etc.), I want a floppy disk icon. And Haiku has one, but I don’t know how to assign it to my USB Thumb Drive.
I’m just giving the options I know of. I understand it may not be what you (or I, for that matter) would prefer, but… such is the state of things, I think.
Maybe you should open a ticket on Trac, and hope a dev can give it some time to try and improve things there.
Good news… Managed to change the icon from a standard BFS volume, to the one for the floppy drive!
Process is a pain in the rear, specially compared to how I remember it was on BeOS’s days, but… Here’s what worked for me:
- Download Haiku’s “Device floppy” icon:
wget https://cgit.haiku-os.org/haiku/plain/data/artwork/icons/Device_Floppy
. - Open the drive for which you want to change the icon with the FileTypes Tracker add-on.
- Right click on the folder icon, select Edit Icon. Icon-O-Matic (IOM) will open.
- On IOM, select
File->Append
and navigate to wherever you downloadedDevice_Floppy
(or other Haiku icon you want). - On IOM, select File->Save. Close IOM.
There! your drive should have a new icon set!
Beware, thou!.. the “Remove icon” from that FileType window did NOT worked for me. To restore the original icon… I had to resort to using the command line:
> rmattr 'BEOS:ICON' /NameOfYourDriveHere
Hope it helps… at least until things get improved, because this process is WAY too convoluted smiley:
Edit: THIS needs to be filed as a Trac ticket if there isn’t one already. Task for when I’m less sleepy
If you can remove it with rmattr, perhaps can you use addattr to change it?
Of course it needs an icon at the right format.
Sure thing! But “it was simply a drag-and-drop operation in BeOS days” is my pain point here
Edit: for the record… I did tried exporting the icon as .hvif [1] and drag-and-droping that without success. Had to use the same “append icon via Icon-O-Matic and save it” method with the .hvif file.
[1] as that’s the format used for BEOS:ICON
attributes, with type: VICON
Hi @Luposian thank you for your kind words!
Sorry for the late response, I have been pretty disconnected from Haiku lately.
I was writing a response to you but as I see that most of it has already been responded by others in this thread I’ll respond here for the benefit of the discussion.
I see you already located the disquette icon in the Haiku repo.
I guess you also noticed the two other icons that feature a disquette but I mention them just in case, they are a few lines below the Device_Floppy one, they’re called Device_USB_Floppy and Device_USB_Zip.
The floppy they use is slightly different from the main floppy one, go figure why…
With regards to being able to customize a drive icon, I’m all for it!
I already upvoted zuMi’s feature request tiquet.
I have been doing this for years in the Mac (and I kind of remember that it was also possible when I was still using Windows XP?) and would love to have it in Haiku also.
To me the ideal way to do it in a portable drive will be to do it in the most portable way possible.
That means so that it not only works in a BeFS formatted volume, but in any filesystem that Haiku is able to write on.
This has the implication that there needs to be a way to export the icon in the Mac .icns icon format (I think this is already possible) and write it in the drive in the same way the Mac does it, with a hidden folder and some files inside it.
Same for Windows.
And ideally also for Linux but I don’t know if there’s some kind of universally accepted solution with regards to volume icons or if it will need a different implementation for every desktop environment.
Uff, too much linuxes
And when the needed ability to deal with other OSs icons is already implemented, it could also be possible to honor the icon customizations done by the user in those other OSs.
This last will feel like a very welcoming detail, I think.
I was able to successfully change the icon of my USB thumb drive to a floppy, but…upon reformatting it, the icon is restored to it’s previous USB pen drive image. Is there a way to permanently change the icon, so even reformatting won’t change it back?
When you reformat, everything on the disk is erased, including the icon. So, no, there is no way, you have to reinstall the icon after formatting.
I’m thinking the only way to make Haiku truly treat a given device as different, is to have something TELL Haiku it’s different. I mean an actual USB floppy drive comes up with the USB floppy drive icon, right? Every time, even if you reformat the floppy, right? But what about that device is telling Haiku its not a USB thumb drive? Something on the controller! The question is… what? What is Haiku looking for, to present a particular device icon?
Alternatively, could you always assign a particular icon type to a specific USB port (assuming they’re numerated or uniquely identified in some way)? Doesn’t matter why (because I know it seems kinda crazy)… I just need to know if it can be done and/or how to.
USB floppy and USB mass storage are different protocols at the USB level and so they use different drivers. The drivers each provide a default icon.
I think you don’t want to write a new driver just for one USB disk. Ok, I mean, you could if you really wanted, take the existing driver, rename a lot of things so it doesn’t conflict, and change the icon, and make this driver work on only one device (identifying its vendor and device ID), and the original driver ignore that device.
The problem is, this “device” is nothing more than a regular USB thumb drive that I want to assign a different icon image to. But I want to be able to assign a permanent icon to it and other thumb drives used on that same port. This is why I thought maybe a particular USB port could be identified/enumerated and assigned a specific icon image when any thumb drive was used on THAT port. I know it doesn’t make any sense as to why I’d want to do this… but I just need to know if it’s at all possible.
Assuming a USB floppy drive will cause Haiku to present a USB floppy icon, will ANY USB floppy drive work, or only some brands? Does Haiku still work with USB floppy drives? What data does the drive present to Haiku that tells it to show a floppy icon?
The drive tells “I’m an USB floppy drive”, which is different from “I’m an USB mass storage device” and is handled differently by the driver. Once the driver knows that, it can (and will) give a different icon to the drive.
This happens entirely inside the driver. Tracker just asks the driver “what is the icon for this device?”
Yes, all USB floppy drives will work the same, it’s a standardized protocol (just like you don’t need specific drivers for each usb thumb drive)
