The folder is shared again, I also put a zip of Bouncer, this doesn’t have a page on my site yet to explain how it works, it’s a suite of different scripts meant to work in tandem with Filer to bounce unwanted emails
Drag your email to Filer where you defined to pass mail to the bouncer shell script, this will check if the sender is on a black / white list and apply the action chosen above, the yab script acts as a GUI where you can set / change where a sender is stored, you can drag e-mails or personal files to extract the mail account and set / change action for black / white / gray list (a contact is in the gray list when not belonging to the list B || W)
This is an explanatory video I made with BSC
This is a video from JamBox,
a sh script builds a db of any audio file stored on bfs volumes and extracts artist, album and title and track number from the attributes, so if you don’t have any files on your haiku discs or they don’t have audio attributes (this can be solved using ArmyKnife ) it will not work
The yab script, using awk, fills the drop-down menus with the related attributes (artist, album, title track), so you can hierarchically select what you want, step by step; you can skip a step by pressing the left icon (i.e. select ACDC, click album icon to select all, click play icon to play all tracks), you can do direct searches, you can do parallel searches (i.e. you remember the title of a track but you don’t remember the album or artist, put the string Bohemian and search, select the track Bohemian Rhapsody, click on the artist or album icon and that’s it, you found the artist / album you were looking for; at the end of your selection press the play icon to create an m3u file that will be played by MediaPlayer, you can immediately play a partial selection by pressing ALT-S or from its menu
