Hi everyone, I’m out of ideas! And so is Haiku documentation! I tried to burn alpha4 on a USB stick using Refus, etcher, and Haiku_on_stick, they all do the same, which is using DD style to format my USB stick, which - unfortunately - my laptop can’t boot to, so I bought a CD, I used Imgbrun on Windows which didn’t succeed, then I bought another one but I used K3b on gnu/linux this time, SUCCESS! I saw the splash screen, but then it says “welcome to kernel land” and “kdebug >” then it expects me to write something.
any ideas, please? respectfully
Edit: probably what caused the CD not to work is the fact that I used the anyboot image instead of .ISO, I will download .ISO then try again.
Edit #2: no, won’t work, it says kdebug and waits for an input.
Also, I also think that is better if you get some nightly image. In the recent nightly you will get the package manager, and could update Haiku, without need to burn a new CD or USB.
Please, tell us if you had success with it.
Enjoy!
Win32imager also uses the “DD style” thing, so, I can’t boot from it.
P.S.: don’t suggest win32imager to anyone, I used it a month ago with PC-BSD, and it caused my 16 GB USB flash memory to turn into 2 MB!! I had to try so many solutions for weeks until I finally found it, and I’m not quite sure that it works 100% as it should.
Please don’t use bold, really. We have set the forum the way we want it to render, and if people want bold or bigger text, they can do it themselves in their web browser.
Use bold only for important parts of your message.
My best solution in all cases is, disable “Secure Boot” in the notebook BIOS. Disable also “UEFI” in the notebook BIOS. If nothing works, turn of “USB3” in the notebook BIOS.
umm, why are you asking? is it wrong to unzip it?!
anyways, when I used Haiku on a stick, I didn’t unzip, because the program says that it needs the zip file, but when I tried with different programs like “Refus” I unzipped.
I will try to burn the the latest .iso file available though this link, if I didn’t succeed, I will give up
I officely give up I tried many times until I was able to get the CD to boot, but was stuck in the splash screen, it won’t pass it, despite the fact that I waited for 5 hours, it’s just keep loading.
I guess I will have to wait untll Haiku moves forward a bit more.
Your ATI Radeon Xpress 1100 chipset is unsupported in Haiku.
There are a couple of tickets in trac for this incompatability: https://dev.haiku-os.org/ticket/3177 https://dev.haiku-os.org/ticket/10540
You’ll probably have to use fail safe video mode, which is set from the boot menu.
Hit space bar while booting to get into that menu.
Wow, thanks but I think that’s not the only reason, another possible reason is probably because one of my USB out-lets is busted (broken) which sometimes caused PC-BSD - along with some other gnu/linux distros - not to boot.
I will try your suggestion and get back to you, thanks for spending your time in helping me, and thanks for all the others who did the same.
