How can I make
a live Haiku USB
on Haiku?
I used falkon to open discuss.haiku
but it crashed.
Then I opened it in web,
I downloaded the haiku r1 beta5 torrent,
double clicked it,
but transmission did nothing.
Not sure what you mean. The site I gave you lists instructions to do this. installing from Haiku does not require downloading an image.
never mind,
I made the bootable usb under linux mint
using gparted to fix some problems on the old usb
and then turn it bootable
using impression
the usb worked fine
now I’ll try to install it on a HP laptop
