How do I make exporting of hexadecimal files work in WebPosititve?
So, I’ve made a PicoBlaze assembler and emulator in JavaScript. It mostly works in WebPositive, however, one crucial thing isn’t working. Namely, after the assembly is finished, it should be possible to download the hexadecimal (.HEX) file. Here is the code I am using for that:
function downloadHex() {
  Loosely based on:
  https://stackoverflow.com/a/33622881/8902065
  if (/WebPositive/.test(navigator.userAgent))
    alert(
        "It's detected you are using WebPositive. 'Download Hexadecimal' didn't work there when we tested it.");
  let hexadecimalString = "";
  for (let i = 0; i < 2 ** 12; i++)
    hexadecimalString += machineCode[i].hex + "\r\n";
  let arrayOfBytes = new Uint8Array(hexadecimalString.length);
  for (let i = 0; i < hexadecimalString.length; i++)
    arrayOfBytes[i] = hexadecimalString.charCodeAt(i);
  const blob = new Blob([ arrayOfBytes ], {
    type : "application/binhex",
    endings : "transparent",
  const url = URL.createObjectURL(blob);
  let link = document.createElement("a");
  link.href = url;
  link.download = "program.hex";
  link.style.display = "none";
  document.body.appendChild(link);
  link.click();
  link.remove();
In WebPositive, it starts “downloading”, but it keeps downloading forever. So, how can I make it work in WebPositive?
The download issue you’re facing might be due to this bug?
That bug should be fixed on 64bit already (the one in the ticket)
But I am not sure this one is the same bug
I don’t think so. We are not actually downloading anything, we are exporting a JavaScript BLOB to a file. Downloads themselves seem to work in WebPositive.
