What’s the haiku equivalent to .bashrc file so I can customize my prompt or system paths
It’s also bashrc. It should be in ~/config/settings/ somewhere… ![]()
Alright I’ll check there when i get back from work
The same issue was also discussed here with a bit more detail:
Thanks for tip
You can use :
/boot/system/settings/etc/profile
/boot/home/config/settings/profile
These are the ones I have identified when I wrote the article on Haiku Insider ![]()
Just using /boot/home/config/settings/profile here for all the alias’s etc.
Is also a way to set number of file descriptors per app somewhere in configs? It’s 512 by default. Would ulimit -Sn 4096 work from /boot/home/config/settings/profile?
