I know this subject will produce some Hot reactions, but how to customize/theme our window in Haiku?
I want to create clearlook from linux to haiku.
How to do it? Is it possible?
Thanks for your answer.
Haiku has a concept of decorators which control the rendering of Window tabs and of controllooks which control the rendering of controls.
Both of these are basically libraries loaded by the app server, if you want to make windows render differently you can create a controllool and decorator.
examples are the Be decorator and Be controllook
edit: so yes, it is very possible. I don’t think anyone did it yet though : )
Some people may or may not like it, but you are free to do whatever you want with the look of your computer here ![]()
As long as you don’t suggest it should be the default for everyone else Haiku install, of course!
