Nice! If you got something ready give a yell, I’ll surely check it out ![]()
I’ve just pushed a new release with fixes for building and running on x86 (32-bit). Because I had to set up a 32-bit install to investigate that, a binary for x86 is also available ![]()
I also tried to make the font size scale according to the window width. The scaling itself now works, but it breaks resizing the window - you can make it wider, but you can’t make it narrower…
Thanks!!! Working fine on 32bit now
(got a local recipe done to build it with haikuporter, makes it easier to create a local package) ![]()
