Help with MemoryError
I was coding some alternative features for a tar.bz2 compressor/decompressor and I noticed a problem handling big data in memory
example: I try to compress my home folder in ram with tar, then I compress the tar object created with bz2 module, but at tar archive creation time, using this object :
tar_data = io.BytesIO()
tar=tarfile.open(fileobj=tar_data,mode='w')
when I exceed more or less 2,5 gigs of ram I receive a MemoryError
 tar_data=create_tar_in_ram_with_attributes(input_paths)
  File "/boot/home/Projects/HTPBZ2/./HTMZ.py", line 1165, in create_tar_in_ram_with_attributes
    tar.add(input_path, arcname=relative_path)
  File "/boot/system/lib/python3.10/tarfile.py", line 2186, in add
    self.add(os.path.join(name, f), os.path.join(arcname, f),
  [Previous line repeated 2 more times]
  File "/boot/system/lib/python3.10/tarfile.py", line 2180, in add
    self.addfile(tarinfo, f)
  File "/boot/system/lib/python3.10/tarfile.py", line 2208, in addfile
    copyfileobj(fileobj, self.fileobj, tarinfo.size, bufsize=bufsize)
  File "/boot/system/lib/python3.10/tarfile.py", line 255, in copyfileobj
    dst.write(buf)
MemoryError
with smaller archives I get no errors. It looks like there is a limit for objects in ram.
I cannot set nor detect free available “app ram” within python with the resource python module, because it’s not set up for Haiku.
Any help is appreciated
Are there any signed 32-bit offsets anywhere? They have a limit of 2 GiB destination address in either direction.
Other than that it might be something in the memory allocator. If the maximum size allocation is 32-bit it would have similar problems to those mentioned above.
Yes, ram is currently limited to about 2 to 3 GB per application on Haiku. We ned to replace or upgrade the memory allocator, but previous attempts have not been successful, resulting in various types of performance degradation: making things slower, not handling low memory situations very well, etc.
If you need larger memory, you may allocate your own area and manage it yourself.
Thanks that is an important information!
