Or just use 8.8.8.8 and 8.8.4.4
Those are Google’s DNS servers. If those go down, you might as well head for the fallout shelter.
Already tried those.
Seems to be browser related as I can’t resolve anything using WebPositive but Depot can find software ![]()
Don’t use Google stuff,it’s a privacy nightmare.
Use Quad9 9.9.9.9 if you want easy IPs to remember,or even Cloudflares 1.1.1.1,but not Googles surveillance crap.
Dismail has a ad and tracker filter built-in as a nice bonus,however.
That’s interesting ![]()
Can you open IPs directly using WebPositive,maybe your routers configuration page (192.168.1.1, 192.168.2.1 or 192.168.178.1 likely)?
Did you try if another browser from HaikuDepot works better for you?
Yup, it was just WebPositive having a seniors moment (or the age of my hardware)
A reboot later and an install of Epiphany and everything is working
PSA: Quad9 is currently blocking https://0x0.st/ for me completely. Double whammy… as 0x0.st already geoblocked me for uploading “pastes” (but at least I could read it). Using the unfiltered 9.9.9.10 would be an alternative (but also a downgrade).
(this DNS side-track could be split from this topic)
Edit: seems they unblocked it now.
Thinkpad T560 works on first try ![]()
Installation is OK with UTM on MacOS with MacBook Pro 2019 ![]()
Note : This configuration is preferred to VirtualBox on Mac where the performances are quite bad (whatever the OS is).
I have added a new infrastructure ticket to do this update here.
(It may be good to likewise add one related to the update of the fonts’ categories).
Gave it a go with Haiku Depot Server: Granting permissions and CSV upload · Issue #132 · haiku/infrastructure · GitHub , though I was a bit reluctant to filing this a bit mondane request among the big picture infrastructure issues filed there ususally…
OK, switched repositories to r1beta5 and did a few reboots to get pkgman to install full updates (no full-sync).
First problem is that Falkon keeps one thread occupied, making one of the cpu’s go full speed which isn’t a nice thing. ![]()
EDIT: actually first issue was (and still seems to be) pkgman not responding, this is a major issue for me as I need it to fetch devel packages for those being updated/not installed.
EDIT2: looks like I can’t build anything anymore (at this moment), not even a simple build for “album” fails with “waiting for package … te be activated”, looking at repositories prefs it looks fine, opening HaikuDepot doesn’t show any repository though?
From syslog launching a build for “album”:
2024-08-20 09:52:53 KERN: unknown: [720162620: 1467] Adding packages from "/Opslag/haikuports/haiku-apps/album/work-0.9.4/boot/system/packages"
2024-08-20 09:52:53 KERN: unknown: [720162623: 1467] Failed to open packages activation file: No such file or directory
2024-08-20 09:52:53 KERN: unknown: [720162624: 1467] Loading packages from activation file failed. Loading all packages in packages directory.
2024-08-20 09:52:53 KERN: packagefs: Failed to get shine-through directory "non-packaged": No such file or directory
2024-08-20 09:52:53 KERN: unknown: [720310592: 1467] StringPool usage:
2024-08-20 09:52:53 KERN: unknown: [720310593: 1467] total unique strings: 388230, 6586657 bytes, overhead: 8929290 bytes
2024-08-20 09:52:53 KERN: unknown: [720310594: 1467] total strings with dups: 2221959, 28013885 bytes
2024-08-20 09:52:53 KERN: unknown: [720310595: 1467] unshared strings: 17675
2024-08-20 09:52:53 KERN: unknown: [720310595: 1467] 2024-08-20 09:52:53 KERN: bytes saved: 12497938
2 posts were split to a new topic: WebPositive Download problems
4 Boxes:
Here are lisdev outputs for all the box.
HP Omen 16 2022 Advantage Edition
device Bridge (Host bridge) [6|0|0]
vendor 1022: Advanced Micro Devices, Inc. [AMD]
device 1630: Renoir/Cezanne Root Complex
device Generic system peripheral (IOMMU) [8|6|0]
device 1631: Renoir/Cezanne IOMMU
device 1632: Renoir PCIe Dummy Host Bridge
device 1633: Renoir PCIe GPP Bridge
vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
device 1478: Navi 10 XL Upstream Port of PCI Express Switch
device 1479: Navi 10 XL Downstream Port of PCI Express Switch
device Display controller [3|80|0]
device 73ff: Navi 23 [Radeon RX 6600/6600 XT/6600M]
device ab28: Navi 21/23 HDMI/DP Audio Controller
device 1634: Renoir/Cezanne PCIe GPP Bridge
vendor 10ec: Realtek Semiconductor Co., Ltd.
device 8168: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
device 2725: Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak]
device Generic system peripheral (SD Host controller) [8|5|1]
vendor 17a0: Genesys Logic, Inc
device 9750: GL9750 SD Host Controller
device Mass storage controller (Non-Volatile memory controller, NVM Ex [1|8|2]
vendor 144d: Samsung Electronics Co Ltd
device a808: NVMe SSD Controller SM981/PM981/PM983
vendor 1344: Micron Technology Inc
device 5405: 2300 NVMe SSD [Santana]
device 1635: Renoir Internal PCIe GPP Bridge to Bus
device 1638: Cezanne [Radeon Vega Series / Radeon Vega Mobile Series]
device 1637: Renoir Radeon High Definition Audio Controller
device Encryption controller [10|80|0]
device 15df: Family 17h (Models 10h-1fh) Platform Security Processor
device Serial bus controller (USB controller, XHCI) [c|3|30]
device 1639: Renoir/Cezanne USB 3.1
device Hub (Unused, Full speed (or root) hub) [9|0|0]
vendor 0000: Unknown
device 0000: Unknown
device Human Interface Device (Boot Interface Subclass, Mouse) [3|1|2]
vendor 0461: Primax Electronics, Ltd
device 4d0f: HP Optical Mouse
device Application Specific Interface (Device Firmware Update) [fe|1|1]
vendor 04f2: Chicony Electronics Co., Ltd
device b735: Unknown
device Wireless (Radio Frequency, Bluetooth) [e0|1|1]
vendor 8087: Intel Corp.
device 0032: AX210 Bluetooth
device Vendor Specific Class (Vendor Specific Subclass, Vendor Specific Protocol) [ff|ff|ff]
vendor 0bda: Realtek Semiconductor Corp.
device 8179: RTL8188EUS 802.11n Wireless Network Adapter
device Mass Storage (SCSI, Bulk-Only) [8|6|50]
vendor 0930: Toshiba Corp.
device 6544: TransMemory-Mini / Kingston DataTraveler 2.0 Stick
device Multimedia controller [4|80|0]
device 15e2: ACP/ACP3X/ACP6x Audio Coprocessor
device 15e3: Family 17h/19h HD Audio Controller
device Serial bus controller (SMBus) [c|5|0]
device 790b: FCH SMBus Controller
device 790e: FCH LPC Bridge
device 166a: Cezanne Data Fabric; Function 0
device 166b: Cezanne Data Fabric; Function 1
device 166c: Cezanne Data Fabric; Function 2
device 166d: Cezanne Data Fabric; Function 3
device 166e: Cezanne Data Fabric; Function 4
device 166f: Cezanne Data Fabric; Function 5
device 1670: Cezanne Data Fabric; Function 6
device 1671: Cezanne Data Fabric; Function 7
MSI Tomahawk x570 Zen 3700X Navi 5600
device 1480: Starship/Matisse Root Complex
device 1481: Starship/Matisse IOMMU
device 1482: Starship/Matisse PCIe Dummy Host Bridge
device 1483: Starship/Matisse GPP Bridge
device 57ad: Matisse Switch Upstream
device 57a3: Matisse PCIe GPP Bridge
vendor 1cc1: ADATA Technology Co., Ltd.
device 8201: XPG SX8200 Pro PCIe Gen3x4 M.2 2280 Solid State Drive
device 10d3: 82574L Gigabit Network Connection
device 8125: RTL8125 2.5GbE Controller
device 2723: Wi-Fi 6 AX200
device 57a4: Matisse PCIe GPP Bridge
device (Unknown) (19:0:0) [13|0|0]
device 1485: Starship/Matisse Reserved SPP
device 149c: Matisse USB 3.0 Host Controller
vendor 1038: SteelSeries ApS
device 1720: Mouse
device 0029: AX200 Bluetooth
device Human Interface Device (No Subclass, None) [3|0|0]
vendor 1462: Micro Star International
device 7c84: Unknown
vendor 05e3: Genesys Logic, Inc.
device 0608: Hub
vendor 2516: Cooler Master Co., Ltd.
device 0051: Unknown
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 7901: FCH SATA Controller [AHCI mode]
device 731f: Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
device ab38: Navi 10 HDMI Audio
device 1484: Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
device 148a: Starship/Matisse PCIe Dummy Function
device 1486: Starship/Matisse Cryptographic Coprocessor PSPCPP
vendor 03f0: HP, Inc
device 0591: Unknown
device 1487: Starship/Matisse HD Audio Controller
device 1440: Matisse/Vermeer Data Fabric: Device 18h; Function 0
device 1441: Matisse/Vermeer Data Fabric: Device 18h; Function 1
device 1442: Matisse/Vermeer Data Fabric: Device 18h; Function 2
device 1443: Matisse/Vermeer Data Fabric: Device 18h; Function 3
device 1444: Matisse/Vermeer Data Fabric: Device 18h; Function 4
device 1445: Matisse/Vermeer Data Fabric: Device 18h; Function 5
device 1446: Matisse/Vermeer Data Fabric: Device 18h; Function 6
device 1447: Matisse/Vermeer Data Fabric: Device 18h; Function 7
AMD APU v1807b
device 15d0: Raven/Raven2 Root Complex
device 15d1: Raven/Raven2 IOMMU
device 1452: Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
device 15d3: Raven/Raven2 PCIe GPP Bridge [6:0]
vendor 15b7: Sandisk Corp
device 5003: WD Blue SN500 / PC SN520 x2 M.2 2280 NVMe SSD
device Input device controller (Gameport controller, Generic) [9|4|0]
vendor 19d4: Quixant Limited
device 0100: Unknown
device Memory controller [5|80|0]
device 0200: Unknown
device Communication controller (Serial controller, 16550) [7|0|2]
device 0a00: Unknown
device 0e00: Unknown
device Communication controller [7|80|1]
device 0c00: Unknown
device 15db: Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
device 15dd: Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
device 15de: Raven/Raven2/Fenghuang HDMI/DP Audio Controller
device 15e0: Raven USB 3.1
device Vendor Specific Class () [ff|0|0]
vendor 2ff4: Quixant Plc
device 7512: Unknown
device 15e1: Raven USB 3.1
device Hub (Unused, Single TT) [9|0|1]
device 0610: Hub
device 0610: Hub
device 0610: Hub
vendor 1fd2: Unknown
device 8102: Unknown
device Human Interface Device (Boot Interface Subclass, Keyboard) [3|1|1]
vendor 045e: Microsoft Corp.
device 0752: Wired Keyboard 400
device Unclassified device (Non-VGA unclassified device) [0|0|0]
device 15e6: Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
device 15dc: Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
device 15e8: Raven/Raven2 Device 24: Function 0
device 15e9: Raven/Raven2 Device 24: Function 1
device 15ea: Raven/Raven2 Device 24: Function 2
device 15eb: Raven/Raven2 Device 24: Function 3
device 15ec: Raven/Raven2 Device 24: Function 4
device 15ed: Raven/Raven2 Device 24: Function 5
device 15ee: Raven/Raven2 Device 24: Function 6
device 15ef: Raven/Raven2 Device 24: Function 7
MacBookPro 2014 i7 nvidia750M
device 0d04: Crystal Well DRAM Controller
device 0d01: Crystal Well PCI Express x16 Controller
vendor 10de: NVIDIA Corporation
device 0fe9: GK107M [GeForce GT 750M Mac Edition]
device 0e1b: GK107 HDMI Audio Controller
device 0d05: Crystal Well PCI Express x8 Controller
device 156d: DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
device Generic system peripheral [8|80|0]
device 156c: DSL5520 Thunderbolt 2 NHI [Falcon Ridge 4C 2013]
device 1549: DSL2210 Thunderbolt Controller [Port Ridge 1C 2011]
vendor 14e4: Broadcom Inc. and subsidiaries
device 1682: NetXtreme BCM57762 Gigabit Ethernet PCIe
device 8c31: 8 Series/C220 Series Chipset Family USB xHCI
vendor 0a5c: Broadcom Corp.
device 4500: BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
vendor 05ac: Apple, Inc.
device 820a: Bluetooth HID Keyboard
device 820b: Bluetooth HID Mouse
device 8289: Bluetooth Host Controller
device 0262: Unknown
device 8406: Internal Memory Card Reader
device Communication controller [7|80|0]
device 8c3a: 8 Series/C220 Series Chipset Family MEI Controller #1
device 8c20: 8 Series/C220 Series Chipset High Definition Audio Controller
device 8c10: 8 Series/C220 Series Chipset Family PCI Express Root Port #1
device 8c14: 8 Series/C220 Series Chipset Family PCI Express Root Port #3
device 43a0: BCM4360 802.11ac Dual Band Wireless Network Adapter
device 8c16: 8 Series/C220 Series Chipset Family PCI Express Root Port #4
device 1570: 720p FaceTime HD Camera
device 8c18: 8 Series/C220 Series Chipset Family PCI Express Root Port #5
device 1600: S4LN053X01 AHCI SSD Controller(Apple slot)
device 8c4b: HM87 Express LPC Controller
device 8c22: 8 Series/C220 Series Chipset Family SMBus Controller
So for all of my AMD GPU boxes (3 of them), I had to disable the Radeon HD driver otherwise they deadlock on rocket icon or KDL in radeon_hd probe.
On my nvme nightly images I have the radeon_hd driver blacklisted.
It is great that there is a radeon_hd driver for Haiku, but it appears only to work with older (pre Vega) chips. Vega, Navi and up seem to not work with the driver.
I’d actually contemplate whether it makes sense to blacklist this driver on the upcoming R5 beta by default. I dont have data, but I wouldn’t be suprised that there are more Vega/Navi + boxes out there than older Radeon GPU’s. Or make a very public note about how to work around the issue.
Why? that would just break people who use this driver for no reason.
Instead you can simply stop it from attaching to certain generations.
Here is a patch for van gogh for the steam deck that does that: https://review.haiku-os.org/c/haiku/+/8043
I missed disabling the driver for newer cards in the beta branch, yes. Honestly I think we should indeed disable it for those generations altogether even in master at this point.
If the driver is supposed to handle those I would be against disabling it on master. It would just make it harder to fix the problems later on. But for beta5 it makes sense to do so
It isn’t, it was enabled in “let’s see what happens” fashion. Now we know what happens, so…
Beta 5 working great on iMac 27" late 2010 Core i3
Unfortunatly in iMac 27" 2015 no boot icon lights up (was the same with beta4 on that machine)
Does someone have an idea?
Thinkpad T560 and T460s works great, more tests to follow
rEFInd offers legacy BIOS boot option, since Mac firmware isnt as good as it could be. This is how I get Haiku booting on MBP 11.3 2014. Your iMac early 2015 should be same motherboard and firmware.
