hello all…
i’m try to make recipe for luckybackup port…
i’ve been test on my vm… package created…
i’m tested compiled application …
but confusing one show here…
when i open application from menu…
the language menu not show language list…
when when i open application from terminal /system/apps/LuckyBackup/LuckyBackup
menu and help show correctly…
Checked and confirmed, I could set to another language when stated from Terminal in the $appsDir, the icon in the About window still doesn’t show though, could be some installation path you should check …
Let me roll Detect Native Language.…
Hmm, too small sample size.
I’ll “take 20” D&D3e-style, and determine…
Indonesian?
Please try to write complete sentences. However, if you are not confident when writing English, perhaps post the same message in both English and Indonesian.
package created. and i try to test it…
double click package file produced to install package…
application name: LuckyBackup
translation and manual folder and content exist corretcly
1.open application via menu
result: languange menu not show (translation folder that contain translation file .qm)
menu about -> help… error not show manual page (html page in folder manual)
2.open via terminal…
LuckyBackup can find manual and traslation folder
manual: menu help -> luckybackup handbook
i’m sure it is a path problem, your binary is looking for manual/index.html relative to executable location, but in your package it shows that LuckyBackup binary is inside manual directory. You need to move it like this
apps
LuckyBackup
LuckyBackup
manual
index.html
PS: even then, you should change the way it looks for that file/directory, either add apps/LuckyBackup/ (installation directory) as a fallback or hardcode it to be the only one used.
…the path have been same with what you suggested… please refers to screenshot…
i still dont understand
whats different between running on terminal vs running via tracker?
LuckBackup binary is looking for manual/index.html in the same directory it is launched from. i.e. if you go to your home dir ~ and launch from there using the full path /system/apps/LuckyBackup/LuckyBackup it wont work becasue it is looking for ~/manual/index.html
