You could use the source code available to help make the driver, but it wonât work by just compiling the driver for Haiku. Feel free to port the driver though.
Reusing BSD sources is a brilliant idea, but in reality it requires a [bit|lot] of work. If you have any programming experience you can look on already ported drivers and try to create the same âglueâ wrappers on base of FreeBSD sources. Or you can just put the new ticket in the Haiku Trac(http://dev.haiku-os.org) in opposite case.
Quick port of AGE FreeBSD driver (Attanstic/Atheros L1 Gigabit Ethernet 10/100/1000) for Haiku - http://slil.ru/27986510
Try it.
I canât test this driver because havenât hardware.
If driver not worked - mail me 3dEyes (at) gmail.com
Nice that youâre helping out here.
I canât test it either, but I do strongly recommend you create a ticket for your effort and attach this file, so it gains more visibility and wonât get forgotten. http://dev.haiku-os.org
[quote=PieterPan]Nice that youâre helping out here.
I canât test it either, but I do strongly recommend you create a ticket for your effort and attach this file, so it gains more visibility and wonât get forgotten. http://dev.haiku-os.org[/quote]
